| Hi there, I am wondering if any one from the forum that has converted from auto to 5 speed, if you have hooked up the neutral switch to the newly installed manual tranny? Reason why I want to do this is because of timing at idle. Since the neutral switch is not connected at the moment, the ecu timing ( at idle/neutral ) at consult will read differently than the mechanical timing. thanks everyone
